Options
‎10-23-2018 02:45 PM
The report below will calculate an estimate of your network's total computing power based on the information available in Lansweeper.
You can find 2 reports below which can be used depending on the Lansweeper version you are using. The Lansweeper 6 report combines the total computing power of Windows, Linux and Macs.
The Lansweeper 7 reports adds VMware server computing power which is new information that is scanned in LS7.
The calculation used to achieve the numbers in the report is as follows:
Performance in TFlops = ((CPU speed in GHz) x (number of CPU cores, if available) x 16) / 1000
Lansweeper 6 report:
Lansweeper 7 report:
Select Top 1000000 (Case
When TflopsWindows.TFlops Is Null Then 0
Else TflopsWindows.TFlops
End) As TflopsWindows,
(Case
When TflopsLinux.TFlops Is Null Then 0
Else TflopsLinux.TFlops
End) As TflopsLinux,
(Case
When TflopsMac.TFlops Is Null Then 0
Else TflopsMac.TFlops
End) As TflopsMac,
((Case
End) + (Case
End) + (Case
End)) As TflopsTotal
From (Select Sum((Cast(tblProcessor.MaxClockSpeed / 1000 As decimal(18,2)) *
tblProcessor.NumberOfCores * 16) / 1000) As TFlops
From tblAssets
Inner Join tblProcessor On tblAssets.AssetID = tblProcessor.AssetID
Where tblAssetCustom.Model Not Like '%virtual%') As TflopsWindows,
(Select Sum((Cast(SubString(tblLinuxProcessors.MaxSpeed, 0, 5) /
1000 As decimal(18,2)) * 4 * 16) / 1000) As TFlops
From tblAssets
Inner Join tblLinuxProcessors On tblAssets.AssetID =
tblLinuxProcessors.AssetID
Where tblAssetCustom.Model Not Like '%virtual%') As TflopsLinux,
(Select Sum(((Cast(SubString(Replace(tblMacHwOverview.CPUSpeed, ',',
''), 0, 4) As decimal(18,2)) / 10) * tblMacHwOverview.NrOfCPUs * 16) /
1000) As TFlops
From tblAssets
Inner Join tblMacHwOverview On
tblAssets.AssetID = tblMacHwOverview.AssetID
Where tblAssetCustom.Model Not Like '%virtual%') As TflopsMac
(Case
(Case
End) As TflopsMac,
(Case
When TflopsESXi.TFlopsVM Is Null Then 0
Else TflopsESXi.TFlopsVM
End) As TflopsESXi,
((Case
End) + (Case
End) + (Case
End) + (Case
From tblAssets
From tblAssets
1000) As TFlops
From tblAssets
Where tblAssetCustom.Model Not Like '%virtual%') As TflopsMac,
(Select Sum((Cast(tblVmwareInfo.CpuMhz / 1000 As decimal(18,2)) *
tblVmwareInfo.numCpuCores * 16) / 1000) As TFlopsVM
From tblAssets
Inner Join tblVmwareInfo On tblAssets.AssetID = tblVmwareInfo.AssetID)
As TflopsESXi
Labels:
Finished Reports
Report Center
12 REPLIES 12
Options
‎10-23-2018 04:29 PM
Teraflops Total : 348.226560
A little way to go....
Options
‎10-23-2018 04:55 PM
Got ya beat, we have a whopping 50!
Options
‎10-23-2018 05:07 PM
Amatures, try flying with a whopping 7.3!
