‎07-16-2015 06:36 PM
tblstate.Statename As [Asset state],
tsysAssetTypes.AssetTypename As [Asset type],
Coalesce(tblOperatingsystem.Caption, tblLinuxSystem.OSRelease,
tblMacOSInfo.SystemVersion, 'other/none') As OS,
tblAssetCustom.Manufacturer,
tblAssetCustom.Model,
tblAssetCustom.Serialnumber,
tblAssetCustom.Warrantydate As [Warranty expiration],
tblAssets.Lastseen,
tblAssets.Domain,
tblADComputers.OU,
tblAssets.IPAddress,
tblAssets.FQDN,
tblADComputers.Description,
tblAssets.Memory,
tblAssets.NrProcessors,
tblAssets.Processor
From tblAssets
Left Join (Select tblAssetUserRelations.AssetID,
tblAssetUserRelations.Username,
tblAssetUserRelations.Userdomain
From tblAssetUserRelations
Where tblAssetUserRelations.Type = 1) tOwner On tblAssets.AssetID =
tOwner.AssetID
Inner Join tblstate On tblstate.State = tblAssetCustom.State
Left Join tblOperatingsystem On tblOperatingsystem.AssetID = tblAssets.AssetID
Left Join tblLinuxSystem On tblAssets.AssetID = tblLinuxSystem.AssetID
Left Join tblMacOSInfo On tblAssets.AssetID = tblMacOSInfo.AssetID
Left Join tblADComputers On tblAssets.AssetID = tblADComputers.AssetID
Solved! Go to Solution.
‎07-17-2015 03:53 PM
tblState.Statename As [Asset state],
tblAssets.Lastseen,
tblAssets.Domain,
tblADComputers.OU,
tblAssets.FQDN,
tblAssets.Memory,
tblAssets.Processor,
tRegistry1.Value As ApplicationName,
tRegistry2.Value As ApplicationOwner,
tRegistry3.Value As DeptName
From tblAssets
tOwner.AssetID
Left Join (Select tblRegistry.AssetID,
tblRegistry.Value
From tblRegistry
Where tblRegistry.Regkey Like 'HKEY_LOCAL_MACHINE\SOFTWARE\Inventory' And
tblRegistry.Valuename = 'ApplicationName') tRegistry1 On tblAssets.AssetID =
tRegistry1.AssetID
tblRegistry.Value
From tblRegistry
tblRegistry.Valuename = 'ApplicationOwner') tRegistry2
On tblAssets.AssetID = tRegistry2.AssetID
tblRegistry.Value
From tblRegistry
tblRegistry.Valuename = 'DeptName') tRegistry3 On tblAssets.AssetID =
tRegistry3.AssetID
‎07-17-2015 04:11 PM
tblAssets.Lastseen,
tblAssets.Domain,
tblADComputers.OU,
tblAssets.FQDN,
tblAssets.Memory,
From tblAssets
tOwner.AssetID
tblRegistry.Value
From tblRegistry
tRegistry1.AssetID
tblRegistry.Value
From tblRegistry
tblRegistry.Value
From tblRegistry
tRegistry3.AssetID
‎07-22-2021 10:26 PM
tsysOS.OSname,
tblADusers.Firstname,
tblADusers.Lastname,
tblAssets.Lastseen,
tRegistry1.Value As JAVA_HOME,
tRegistry2.Value As JAVA_TOOL_OPTIONS,
tRegistry3.Value As PATH
From tblAssets
tOwner.AssetID
tblRegistry.Value
From tblRegistry
Where
'HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Environment' And tblRegistry.Valuename = 'JAVA_HOME') tRegistry1 On tblAssets.AssetID = tRegistry1.AssetID
tblRegistry.Value
From tblRegistry
Where
'HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Environment' And tblRegistry.Valuename = 'JAVA_TOOL_OPTIONS') tRegistry2 On tblAssets.AssetID = tRegistry2.AssetID
tblRegistry.Value
From tblRegistry
Where
'HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Environment' And tblRegistry.Valuename = 'PATH') tRegistry3 On tblAssets.AssetID = tRegistry3.AssetID
Inner Join lansweeperdb.dbo.tsysOS On tsysOS.OScode = tblAssets.OScode
Inner Join lansweeperdb.dbo.tblADusers On tblADusers.Username =
tblAssets.Username
Where tsysAssetTypes.AssetTypename = 'Windows' And tblAssetCustom.State = 1
tblAssets.Username,
tsysIPLocations.IPLocation,
tsysOS.OSname As OS,
Case
When tblSoftware.softwareVersion >= '8.0.1810.13' Then 'Up to date'
Else 'Out of date'
End As [Patch Status],
tblSoftware.softwareVersion As Version,
tblSoftwareUni.softwareName As Software,
tblSoftwareUni.SoftwarePublisher As Publisher,
tblAssets.Lastseen,
tblAssets.Lasttried,
Case
When tblSoftware.softwareVersion < '8.0.1810.13' Then '#ffadad'
Else '#d4f4be'
End As backgroundcolor
From tblAssets
tblAssets.LocationID
Inner Join tblSoftware On tblAssets.AssetID = tblSoftware.AssetID
Left Join tsysOS On tsysOS.OScode = tblAssets.OScode
Inner Join tblADusers On tblADusers.Username = tblAssets.Username
Where tblSoftwareUni.softwareName Like '%Java%' And tblState.Statename =
'Active'
Order By Version
Daniel.B wrote:
If you would like to list all assets, even if they don't have data stored for this registry value, you need to use a subquery and make Left Join to it. If additionally you want to put all the values into one row of your report, you could use multiple subqueries, one for each value. Please find a modified report below which lists 3 of the values.
tblAssets.Lastseen,
tblAssets.Domain,
tblADComputers.OU,
tblAssets.FQDN,
tblAssets.Memory,
From tblAssets
tOwner.AssetID
tblRegistry.Value
From tblRegistry
tRegistry1.AssetID
tblRegistry.Value
From tblRegistry
tblRegistry.Value
From tblRegistry
tRegistry3.AssetID
