runiuksp
I need a really simple report:
Computer Name
IP location
OsName - Windows 7
IE browser - version 8
Could you help please?
The report below lists the IE8 installations on your Windows 7 computers. We assume this is what you're after. To use the report below, do the following:
•Open the report builder under Reports/Create New Report.
•Paste the SQL code we provided at the bottom of the page.
•Left-click somewhere in the upper section of the page so the code applies.
•Give the report a Title and hit the Save & Run button to save it. Export options are listed on the left.
tblAssets.AssetID,
tblAssets.Domain,
tblAssets.IPAddress,
tsysIPLocations.IPLocation,
tsysOS.OSname,
tblSoftwareUni.softwareName,
tblAssets.Firstseen,
tblAssets.Lastseen
From tblAssets
Inner Join tblSoftware On tblAssets.AssetID = tblSoftware.AssetID
Left Join tsysIPLocations On tblAssets.IPNumeric >= tsysIPLocations.StartIP
And tblAssets.IPNumeric <= tsysIPLocations.EndIP
Where tsysOS.OSname = 'win 7' And tblSoftwareUni.softwareName Like
'windows internet explorer 8%' And tblAssetCustom.State = 1
Order By tblAssets.Domain,
tblAssets.AssetName
runiuksp
That's great!
Many thanks
Would you be able to do kind of similar one that will show all computers with google chrome not installed?
runiuksp wrote:
That's great!
Many thanks
A sample report can be found here.
tblAssets.AssetID,
tblAssets.Domain,
tsysOS.OSname,
tblAssets.Lastseen
From tblAssets
tblAssets.AssetName
Reports & Analytics
