‎02-16-2024 03:26 PM - edited ‎02-16-2024 03:27 PM
I am trying to create a report that shows systems that have an application installed "x" and when installed the version is not "y" or "z". I have several of these type reports that work fine when I am only looking at one version. With the version being a string and not a number I can't use greater than to evaluate. Below is what I have but it returns no systems, and I am 100% sure there are systems that don't have either version of the application installed. Does anyone know how to make this work, assuming it is even possible?
Thank you very much.
From tblAssets
Inner Join tblSoftware On tblAssets.AssetID = tblSoftware.AssetID
Inner Join tblSoftwareUni On tblSoftware.softID = tblSoftwareUni.SoftID
Where tblSoftwareUni.softwareName Like 'x' And
tblSoftware.softwareVersion Not Like 'y%' And
tblSoftware.softwareVersion Not Like 'z%' And tblAssetCustom.State = 1
Report Center
‎02-21-2024 05:26 AM
what is the full version standard? X.X.X.X , or X.X.X ?
‎02-19-2024 05:36 AM
Try this:
Select Top 1000000 tblassets.AssetID,
tblassets.AssetName,
tblassets.IPAddress,
tblassets.Lastseen,
tblassets.Lasttried,
From tblassets
Inner Join tblSoftware On tblassets.AssetID = tblSoftware.AssetID
Where tblassets.AssetID Not In (Select Top 1000000 tblSoftware.AssetID
From tblSoftware Inner Join tblSoftwareUni On tblSoftwareUni.SoftID =
tblSoftware.softID
Where (tblSoftwareUni.softwareName Like '%finereader 9%' Or
tblSoftwareUni.softwareName Like '%finereader 11%')) And
tblSoftwareUni.softwareName Like '%finereader 12%'
‎02-19-2024 05:52 PM
unfortunately for the application I am trying to generate the report on, the version is not stored with the software name so including the version with the name did not work.
‎02-19-2024 06:03 PM
You can change code of sql to version
‎02-19-2024 06:07 PM
ok, I tried this as well and it too returns nothing. When I try to add the extra parentheses that your response has, the report editor just removes them.
(tblSoftware.softwareVersion Not Like 'y%' Or
tblSoftware.softwareVersion Not Like 'z%') And tblAssetCustom.State = 1
‎02-19-2024 06:19 PM - edited ‎02-20-2024 04:56 PM
Don't use 'not like' with 'or'
‎02-19-2024 06:18 PM
You should use my query logics.
Please send full code not cut
‎02-19-2024 06:29 PM
I apologize for not understanding your query logic. I thought I was correctly interpreting your suggestion and updating the query. Below is the full code of the query.
tblAssets.Domain,
tblSoftwareUni.softwareName,
tblSoftware.softwareVersion,
tblSoftware.Installdate,
tblAssets.Lastseen,
tblAssets.Username,
tblAssets.IPAddress
From tblAssets
Order By tblAssets.Domain,
tblAssets.AssetName
‎02-20-2024 05:08 AM
Obviously,
expression (tblSoftware.softwareVersion Not Like 'y%' Or tblSoftware.softwareVersion Not Like 'z%') is always true.
