Obi_1_Cinobi
Question
How do I migrate my existing console running under IIS Express to IIS Server?
Answer
To migrate your existing console running under IIS Express (the default web server), to IIS Server, please reinstall the web console by following these instructions:
https://www.lansweeper.com/knowledgebase/how-to-reinstall-your-lansweeper-website/
  • When you get to this step "Select the web server you'd like to install the console under", choose the Advanced (IIS) option.
  • Do note that IIS must be enabled on the machine to be able to get this option. If you haven't yet, enable and install Internet Information Services on your Lansweeper server via Add/Remove Programs. Specifically the full Web Management Tools and World Wide Web Services feature list. For more information, you can refer to this KB article:
No ratings
‎12-08-2025 08:59 AM
