Two new vulnerabilities in Scheider Electric OT devices can cause arbitrary code execution, denial of service and more! Read more about which products are affected and grab the in the Schneider Electric blog post.
Hi, everytime I click on the URL to run the Schneider Electric Vulnerability Audit, I'm getting redirected to a login. There I need to link our local instance with the cloud. That's not what I want. Any possibility to get the report without the cloud instance?
The report is cloud only because data captured using the OT scanner is only available for reporting in cloud. I am not that familiar with the specific devices to know whether retrieving the required data via SNMP is possible, but that would be the Lansweeper classic alternative if it is.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
