Tomas
hi,
how would i perform a query which shows AD Users for a given year.
I.E.
Year - Users
2014 - 1500
2015 - 1600
2016 - 1650
2017 - 1700
Using the "Date Created" and "Last Scaned" to determin if a user was active at the time.
Nick_VDB
It is unfortunately not possible to determine if a user was active during a specific year and then report this information. Lansweeper will only give back the date when the user was created but not scan if the user was enabled/disabled. The Lastscanned field will also not help in this situation as this field will only give back the date when the tblADObjects table was modified.
We did add a report below that will give back a count of all the AD users created per year.
Select Top 1000000 DatePart(yyyy, tblADusers.whenChanged) As Year,
Count(tblADusers.ADUserID) As Users
From tblADusers
Group By DatePart(yyyy, tblADusers.whenChanged)
Tomas
Thank you,
in our case 'modified' would work, because there a scripts in place that update some info on the AD user regularly.
Nick_VDB
From tblADusers
