marco_backup
Good morning support!
I installed the new version.
How do I denied the access to all user?
I want allow access to few users.
Thank you
Marco
6 REPLIES 6
taeratrin
Also note that if you use the LS installer to install IIS, you need to go back into your roles and add Windows Authentication.
marco_backup
OK.
Sorry if I want "migrate" to IIS what do I do?
Do I need reinstall?
Thank you
marco.backup wrote:
OK.
Thank you
Install IIS
Run the setup and choose only to install the website.
marco_backup
Thank you but if i use lansweeper build-in webserver ?
It's only possible with IIS
See: http://www.lansweeper.com/kb/restrict.aspx
