LithiumKid1976
hi
how can i get a breakdown of what verions of sql 2005 are installed on the domain.?
when i check under software reports, it has 45 instances of sql, but it would be handy to see if it was the enterprise or basic, as there is a massive cost difernce between the two.
You are not the first one asking this question, there are some more in the forum.
So far I think none have found a good solution.
