emaster
I got all the first steps finally done but cannot get page to browse properly. I get all the icons fine but when it comes up it shows:
System.ArgumentException: Keyword not supported: 'source'.
at System.Data.Common.DBConnectionString.ParseInternal(Char[] connectionString, UdlSupport checkForUdl, NameValuePair& keychain)
at System.Data.Common.DBConnectionString..ctor(String connectionString, UdlSupport checkForUdl)
at System.Data.SqlClient.SqlConnectionString..ctor(String connectionString)
at System.Data.SqlClient.SqlConnectionString.ParseString(String connectionString)
at System.Data.SqlClient.SqlConnection.set_ConnectionString(String value)
at System.Data.SqlClient.SqlConnection..ctor(String connectionString)
at DreamweaverCtrls.DataSet.NewDbConnection(String strConnection)
Can you help?
emaster
Soory, got it to work. Web Config file had wrong info in server name.
Excellent Tool. Give you much thanks for it.
