toby_pruitt
Has anyone created a batch script that works with Office 365 click to run installer created with the Office Deployment tool? If I run the batch file locally it works, when I try and deploy it through Lansweeper it doesn't run. The installer log says the script executed successfully but nothing happens on the target PC
Barbapat
Hi , i try this in my lab and work. noy i'm going to test a batch that can first check for any previous version of Office and , if necessary, remove them. give me a feedback please. thanks
