‎09-25-2008 01:26 AM
In the test server we install everything in the same computer (lanswweper service, sql database and website) but in the production server we install each one of the components in a different server. For example the service in SERVER04, the database in SERVER02 (SQL Server 2005) and the website in SERVER01 (IIS 6.0).
The service detect all the computers but only collects data from SERVER04, that is, the Server where the service is running.
In the Error Log we see a lot of errors but they are very similar. I copy here the two most frequent:
9/16/2008 4:21:57 PM : ZEUS
System.Runtime.InteropServices.COMException (0x8007054B): The specified domain either does not exist or could not be contacted. (Exception from HRESULT: 0x8007054B)
at Microsoft.VisualBasic.CompilerServices.LateBinding.InternalLateCall(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack, Boolean IgnoreReturn)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateCall(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack, Boolean IgnoreReturn)
at Lansweeper31.sweeperthread.LSADusersearch(clsComputer mycomputer, clsThreadinfo Threadinfo, SqlConnection& sqlcon)
TM\yaisell
The other error is this:
9/22/2008 8:34:11 AM : E010603
System.UnauthorizedAccessException: Access is denied. (Exception from HRESULT: 0x80070005 (E_ACCESSDENIED))
TM\sisi
Please answer back as soon as you can because we tried almost everything for a week and can'r understand why the applications doesn't run. We compare the configuration of the test server with the Production server and find everything identical.
‎10-14-2008 07:09 PM
(Better ask in an active directory support forum)
‎10-14-2008 05:28 PM
The results of running DCDIAG in my domain controller are here: (i change the server name to <my server> for security reasons)
C:\WINDOWS\ServicePackFiles\i386>dcdiag /s:<myserver>
Domain Controller Diagnosis
Performing initial setup:
Done gathering initial info.
Doing initial required tests
Testing server: Default-First-Site-Name\<MYSERVER>
Starting test: Connectivity
......................... <MYSERVER> passed test Connectivity
Doing primary tests
Starting test: Replications
......................... <MYSERVER> passed test Replications
Starting test: NCSecDesc
......................... <MYSERVER> passed test NCSecDesc
Starting test: NetLogons
Unable to connect to the NETLOGON share! (\\<MYSERVER>\netlogon)
[<MYSERVER>] An net use or LsaPolicy operation failed with error 1203, No
network provider accepted the given network path..
......................... <MYSERVER> failed test NetLogons
Starting test: Advertising
......................... <MYSERVER> passed test Advertising
Starting test: KnowsOfRoleHolders
Warning: CN="NTDS Settings
DEL:c4ff185f-b434-470f-a838-098a91a50c7c",CN=<MYSERVER>,CN=Servers,CN=Default-Firs
t-Site-Name,CN=Sites,CN=Configuration,DC=tm,DC=minbas,DC=cu is the Schema Owner,
but is deleted.
t-Site-Name,CN=Sites,CN=Configuration,DC=tm,DC=minbas,DC=cu is the Domain Owner,
but is deleted.
......................... <MYSERVER> failed test KnowsOfRoleHolders
Starting test: RidManager
......................... <MYSERVER> passed test RidManager
Starting test: MachineAccount
......................... <MYSERVER> passed test MachineAccount
Starting test: Services
......................... <MYSERVER> passed test Services
Starting test: ObjectsReplicated
......................... <MYSERVER> passed test ObjectsReplicated
Starting test: frssysvol
......................... <MYSERVER> passed test frssysvol
Starting test: frsevent
There are warning or error events within the last 24 hours after the
SYSVOL has been shared. Failing SYSVOL replication problems may cause
Group Policy problems.
......................... <MYSERVER> failed test frsevent
Starting test: kccevent
An Warning Event occured. EventID: 0x8000043B
Time Generated: 10/14/2008 09:09:01
(Event String could not be retrieved)
An Warning Event occured. EventID: 0x800004F1
Time Generated: 10/14/2008 09:12:12
Time Generated: 10/14/2008 09:14:00
......................... <MYSERVER> failed test kccevent
Starting test: systemlog
An Error Event occured. EventID: 0x0000165B
Time Generated: 10/14/2008 08:57:47
Event String: The session setup from computer 'LIMITADO' failed
An Error Event occured. EventID: 0x0000169E
Time Generated: 10/14/2008 09:00:33
Event String: No suitable Domain Controller is available for
An Error Event occured. EventID: 0x00003006
Time Generated: 10/14/2008 09:04:00
Event String: The SAM database was unable to lockout the
......................... <MYSERVER> failed test systemlog
Starting test: VerifyReferences
......................... <MYSERVER> passed test VerifyReferences
Running partition tests on : Schema
Starting test: CrossRefValidation
......................... Schema passed test CrossRefValidation
Starting test: CheckSDRefDom
......................... Schema passed test CheckSDRefDom
Running partition tests on : Configuration
......................... Configuration passed test CrossRefValidation
......................... Configuration passed test CheckSDRefDom
Running partition tests on : tm
......................... tm passed test CrossRefValidation
......................... tm passed test CheckSDRefDom
Running enterprise tests on : tm.minbas.cu
Starting test: Intersite
......................... tm.minbas.cu passed test Intersite
Starting test: FsmoCheck
......................... tm.minbas.cu passed test FsmoCheck
‎10-14-2008 09:16 AM
For some reason the lansweeper service cannot contact your domaincontroller.
Could you try a "dcdiag" on the domaincontrollers in the enterprise please.
‎10-14-2008 01:22 AM
‎09-26-2008 10:18 PM
9/12/2008 2:46:23 PM : Database connection successful, starting up service
9/14/2008 3:51:55 PM : Cannot connect to database, check your config file, will try again in 1 minute
Cannot open database "Lansweeper31" requested by the login. The login failed.
Login failed for user 'lssqluser31'.
9/14/2008 3:53:07 PM : Database connection successful, starting up service
TM\yaisell
9/16/2008 4:30:19 PM : LUIS
TM\luib
TM\sisi
9/22/2008 9:05:20 AM : NANCYPER1
TM\impresora
9/22/2008 10:01:04 AM : DANIEL
TM\daniel
9/22/2008 10:39:21 AM : YAMIL
TM\yamil
9/22/2008 4:46:05 PM : SERGIO
TM\administrator
9/22/2008 5:21:02 PM : YAIR
TM\yair
9/23/2008 8:04:32 AM : E010605
TM\doralina
9/23/2008 8:10:25 AM : BABY
System.Runtime.InteropServices.COMException (0x80090350): The system detected a possible attempt to compromise security. Please ensure that you can contact the server that authenticated you. (Exception from HRESULT: 0x80090350)
TM\baby
9/23/2008 8:13:32 AM : MICHEL
TM\michel
9/23/2008 8:16:40 AM : LUIS
TM\luib
9/23/2008 8:19:27 AM : YURITZAPILOTO
TM\yuritza
9/23/2008 8:58:31 AM : YULAINE
TM\yulaine
9/23/2008 11:42:11 AM : JESUSLAPTOP
TM\jhernandez
9/23/2008 1:15:25 PM : QUINTERO
TM\quintero
9/23/2008 4:20:05 PM : SERVER04
TM\administrator
9/23/2008 4:23:46 PM : TM-52271F53A330
TM\davidluis
9/23/2008 4:23:49 PM : RAMON
TM\marthab
9/23/2008 5:32:30 PM : SPS
TM\Administrator
9/24/2008 7:01:27 AM : YAIR
TM\yair
9/24/2008 8:30:58 AM : SPS
TM\Administrator
9/24/2008 8:31:02 AM : YURITZAPILOTO
TM\yuritza
9/24/2008 8:31:11 AM : RUBEN
TM\ruben
9/24/2008 10:39:18 AM : YOANI
TM\yoani
9/24/2008 1:28:54 PM : YOANI
TM\yoani
9/24/2008 2:49:41 PM : SERVER04
TM\administrator
9/24/2008 2:53:12 PM : SERVER04
TM\administrator
9/24/2008 2:55:07 PM : SERVER04
TM\Kaspadm
9/24/2008 2:56:23 PM : SERVER04
TM\lansweeper
9/24/2008 2:58:06 PM : SERVER04
TM\lansweeper
9/24/2008 4:48:26 PM : AESTEVEZ
TM\aestevez
9/24/2008 4:49:53 PM : SERVER04
TM\kaspadm
9/24/2008 5:03:01 PM : SERVER04
TM\administrator
‎09-26-2008 10:14 PM
‎09-26-2008 06:14 PM
‎09-26-2008 03:55 PM
We try several scenaries, the account used for the service is of course member opf the domain adminintrators group. At first we use a different account but later we change the account in the test computer to the same account we use in the production server and everything works fine.
Yes, and we also try different approaches running lsclient manually from some computers. By the way, the connection testewr works fine and the 9524 prot appears as listening in the netstat command in the production server, the same as in the test computer.
‎09-25-2008 12:52 PM
Is the service on server04 installed with the same useraccount as in test?
Did you change lsclient.exe to point to server04?
