logan5
cnok.gif icon no longer being used after upgrade to 3.5.1 from 3.5
31 REPLIES 31
logan5
Ok Ran the script and it looks fixed now! Awesome Thank you! 🙂 Do you know how we ended up with blank spaces in that field? Is it something we did?
Most likely you added it by accident after loading the script
Found the problem, running this script should fix it.
In the second 'NOT SCANNED' there were 2 spaces in your version of the database (I checked the installer script and there it's ok)
ALTER PROCEDURE [dbo].[Web30computers](@domain varchar(80))
AS SELECT dbo.tblComputers.Computername, ISNULL(dbo.tblOperatingsystem.Description, '') AS thedescription, dbo.tblOperatingsystem.Caption AS OS,
CASE ISNULL(dbo.tblOperatingsystem.Description, 'NOT SCANNED') WHEN 'NOT SCANNED' THEN 1 ELSE 0 END AS Notscanned,
CAST(dbo.web30ProcessorCapacity.NrOfProcessors AS varchar) + ' * ' + CAST(dbo.web30ProcessorCapacity.MaxClockSpeed AS varchar)
+ ' Mhz' AS Processor, CAST(CAST(CAST(dbo.tblComputersystem.TotalPhysicalMemory AS bigint) / 1024 / 1024 AS NUMERIC) AS varchar)
+ ' MB' AS Memory, dbo.tblComputers.Lastseen, dbo.tblComputers.LastknownIP, dbo.web30repallcompstates.Thestate
FROM dbo.tblComputers INNER JOIN
dbo.web30repallcompstates ON dbo.tblComputers.Computername = dbo.web30repallcompstates.Computername LEFT OUTER JOIN
dbo.web30ProcessorCapacity ON dbo.tblComputers.Computername = dbo.web30ProcessorCapacity.Computername LEFT OUTER JOIN
dbo.tblComputersystem ON dbo.tblComputers.Computername = dbo.tblComputersystem.Computername LEFT OUTER JOIN
dbo.tblOperatingsystem ON dbo.tblComputers.Computername = dbo.tblOperatingsystem.Computername
WHERE (dbo.tblComputers.Domain LIKE @domain)
GO
logan5
Ok uploaded to Rapidshare, (got the email working but it was rejected in transport as too large.) Sent you the link this a.m.
Did you send me the link?
Can't seem to find it.
logan5
ok compression worked ok zipping to 7zip file. from 147 to 11mbs so sending via email should work ok. Let me know if you can open Ok. (If you don't have 7-zip you can download from: http://www.7-zip.org/, a free open source zipping utility.)
No, If you password protect it you can use Rapidshare
logan5
do you have an ftp site we can upload to?
Could you take a backup/zip it and upload it somewhere?
