kwgagel
Lansweeper client connection always fails from the client. It even fails on the server itself...
Lansweeper connection test works on the server to itself and to a workstation using the account that lansweeper is running with.
I cannot get lansweeper 3.5 to work at all except on the server. It detects only itself an nothing else. Firewall's are disabled on the client and the server for debugging.
service/error.log contains no errors, it says the connection to db is successful and starting service. The application event log indicates it started without errors.
I can use the web console and gui to log in.
Kevin
jreimer1
I think i got it working again had to restart the services and disable windows firewall and Internet sharing service. Even know i am not running firewall and it shows it was turned off. Right now it is processing client so we will see again.
1) is your service running.
2) do you seen any errors in the errorlog.txt
3) is a firewall blocking the port.
jreimer1
I have this same issue again (Second time now) after a upgrade and now i can't access http\\:127.0.0.1:9524
What else should i look at.
Running Symantec Endpoint Protection.
On the server itself are you able to surf to http://127.0.0.1:9524
Make sure that this port is not firewalled on the server.
