Merbecks
we use the lansweeper32 freeware version.
The report "WMI access denied" shows 356 items, but on the left you see "All systems: 227, not scanned 156".(Screenshot attached)
We deleted a lot of computers in the managment console - is it possible, that this wrong counts are the consequence of deleting?
Kind Regards,
Daniel Merbecks
Merbecks
thanks for the answer. I've tried it - and sorry, this seems not to work. I've found the error, why the count of never scanned os was rising the last 2 days - the user running lansweeper server had changed the password...
So would it be a good idea to wait until thuesday or so and than run the code
delete from tblerrors where computername in ('Name1', 'Name2', 'Name3', ...)
go
So i could delete them manual. Not the nice way but I think after that it would work, ...
Other idea: What if i use a statement like
delete from tlberrors where ErrorText Like 'Zugriff verweigert (Ausnahme von HRESULT:%'
If all computers would be scanned again, the "normal" errors would return again... by the way: What's the column-name for errortext?
Kind Regards,
Daniel Merbecks
Could you try the following from the sql script console
delete from tblerrors where computername not in (select computername from tblcomputers)
