‎04-15-2010 12:22 AM
‎04-18-2010 08:58 PM
‎04-18-2010 08:52 PM
‎04-18-2010 08:51 PM
There is already an object named 'tsysdeviceactions' in the database.
Msg 2705, Level 16, State 4, Line 3
Column names in each table must be unique. Column name 'IPscanThreads' in table 'tsysASServers' is specified more than once.
Msg 4924, Level 16, State 1, Line 2
ALTER TABLE DROP COLUMN failed because column 'Day1' does not exist in table 'tsysASServers'.
Column names in each table must be unique. Column name 'Devicetypelock' in table 'tblCustDevices' is specified more than once.
Msg 2705, Level 16, State 4, Line 2
Column names in each table must be unique. Column name 'Snmpblank' in table 'tsysIPScanRanges' is specified more than once.
Column names in each table must be unique. Column name 'Admingroup' in table 'tblUsersInGrouphist' is specified more than once.
Msg 2705, Level 16, State 4, Line 1
Column names in each table must be unique. Column name 'Admingroup' in table 'tblUsersInGroup' is specified more than once.
Column names in each table must be unique. Column name 'BuildInAdmin' in table 'tblUsers' is specified more than once.
Column names in each table must be unique. Column name 'BuildInAdmin' in table 'tblUsershist' is specified more than once.
(0 row(s) affected)
Column names in each table must be unique. Column name 'Schemaversion' in table 'TsysConfig' is specified more than once.
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
Msg 2627, Level 14, State 1, Line 2
Violation of PRIMARY KEY constraint 'PK__tsysDevicetypes__697342E8'. Cannot insert duplicate key in object 'dbo.tsysdevicetypes'.
The statement has been terminated.
Msg 2627, Level 14, State 1, Line 3
Msg 2627, Level 14, State 1, Line 4
Msg 2627, Level 14, State 1, Line 5
Msg 2627, Level 14, State 1, Line 6
(27 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
(1 row(s) affected)
Violation of PRIMARY KEY constraint 'PK_tsysreports'. Cannot insert duplicate key in object 'dbo.tsysreports'.
(1 row(s) affected)
Msg 2714, Level 16, State 3, Procedure web40DevActionsA, Line 3
There is already an object named 'web40DevActionsA' in the database.
Msg 2714, Level 16, State 3, Procedure web40DevActionsB, Line 3
There is already an object named 'web40DevActionsB' in the database.
Violation of PRIMARY KEY constraint 'PK__tsysvendorlogos__7F827F98'. Cannot insert duplicate key in object 'dbo.tsysvendorlogos'.
Column names in each table must be unique. Column name 'Scanserver' in table 'tblcomputers' is specified more than once.
Column names in each table must be unique. Column name 'ReplID' in table 'tblcomputers' is specified more than once.
Column names in each table must be unique. Column name 'ReplSite' in table 'tblcomputers' is specified more than once.
Column names in each table must be unique. Column name 'OScode' in table 'tblcomputers' is specified more than once.
Column names in each table must be unique. Column name 'SP' in table 'tblcomputers' is specified more than once.
Column names in each table must be unique. Column name 'Description' in table 'tblcomputers' is specified more than once.
Violation of PRIMARY KEY constraint 'PK_tsysSerials'. Cannot insert duplicate key in object 'dbo.tsysserials'.
Msg 2627, Level 14, State 1, Line 1
(1109 row(s) affected)
(1 row(s) affected)
‎04-18-2010 08:48 PM
‎04-18-2010 08:49 PM
AdmJLovejoy wrote:
That did it. Problem solved
Did you see any errors during the upgrade?
I have no idea what caused this.
‎04-17-2010 10:32 AM
‎04-16-2010 11:29 PM
‎04-16-2010 03:25 AM
‎04-16-2010 08:23 AM
AdmJLovejoy wrote:
in-place upgrade from the prior beta (Version: 12 March > Version: 12 April)
Is table tsysdeviceactions empty?
I don't see anything that might cause this.
