NeilL
Hi
I seem to be getting this error a lot
4/18/2010 10:47:09 AM: DOMAIN\XXXXXXXXXXX\1 Could not allocate space for object 'dbo.TsysLastscan'.'PK_TsysLastscan' in database 'lansweeperdb' because the 'PRIMARY' filegroup is full. Create disk space by deleting unneeded files, dropping objects in the filegroup, adding additional files to the filegroup, or setting autogrowth on for existing files in the filegroup.
at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe)
at System.Data.SqlClient.SqlCommand.ExecuteNonQuery()
at LansweeperService.sweeperthread.UpdateLastScan(LS_Computer& mycomputer, String section, DateTime startdate, SqlConnection& sqlcon)
4/18/2010 10:47:12 AM: DOMAIN\XXXXXXXXXXX\1 The parameterized query '(@computername nvarchar(4000))select * from tblcompcustom where ' expects the parameter '@computername', which was not supplied.
at System.Data.Common.DbDataAdapter.Fill(DataTable[] dataTables, Int32 startRecord, Int32 maxRecords, IDbCommand command, CommandBehavior behavior)
at System.Data.Common.DbDataAdapter.Fill(DataTable dataTable)
at LansweeperService.sweeperthread.SubMakeActive(LS_Computer& mycomputer, SqlConnection& sqlcon)
4/18/2010 10:47:12 AM: DOMAIN\XXXXXXXXXXX\1 The parameterized query '(@computername nvarchar(4000),@ipadres nvarchar(14))update tblCo' expects the parameter '@computername', which was not supplied.
at LansweeperService.sweeperthread.UpdateIPandScanningServer(LS_Computer mycomputer, SqlConnection& sqlcon)
4/18/2010 10:47:12 AM: DOMAIN\XXXXXXXXXXX\1 The parameterized query '(@computername nvarchar(4000),@scanserver nvarchar(11))update tb' expects the parameter '@computername', which was not supplied.
4/18/2010 10:47:16 AM: DOMAIN\XXXXXXXXXXX$ Active directory computer lookup The parameterized query '(@computername nvarchar(4000))select * from tblADComputers where' expects the parameter '@computername', which was not supplied.
4/18/2010 10:47:16 AM: DOMAIN\XXXXXXXXXXX\1 The parameterized query '(@computername nvarchar(4000))select * from TsysLastscan where c' expects the parameter '@computername', which was not supplied.
at LansweeperService.sweeperthread.TheSweeper(Object myThreadinfo)
4/18/2010 10:47:16 AM: XXXXXXXXXXX REGISTRY The parameterized query '(@computername nvarchar(4000))SELECT * FROM tblregistry WHERE co' expects the parameter '@computername', which was not supplied.
My Errorlog.txt file is 46 Mb 🙂 so I stopped the service.
13 REPLIES 13
-First stop the service
-Run sql command
truncate table tblntlogevent
-Run sql command
DBCC SHRINKDATABASE (@curdb,10) WITH NO_INFOMSGS
GO
NeilL
I have over 10,000 and it still not finished 🙂
PC=6050
Server =3
Not Scanned=4173
PC=6050
Server =3
Not Scanned=4173
Looks like you will need another version of SQL server. to store everything
NeilL
Lansweeper wrote:
PC=6050
Server =3
Not Scanned=4173
What would you suggest 🙂 How about Oracle any support for that?
NeilL wrote:
Lansweeper wrote:
PC=6050
Server =3
Not Scanned=4173
Any version except sql express will do.
Oracle is not supported, only sql server.
If you want to keep sql express you can also disable eventlog scanning to save (much) space.
NeilL
Set the eventlog scanning should it be set to -1?
Set eventlog waittime to -1
Delete everything in table tbleventlog
Shrink the database.
(stop the service first)
NeilL
Okay did this Set eventlog waittime to -1
Don't know how to do these: (some insight would be good or I can ask my oracle guru's tomorrow):D
Shrink the database
NeilL
Only 4 Gb 🙂
