sturmeyp
Are there any issues with running two copies of Lansweeper on the same phyiscal network sharing the same IP range.
My company is split into two divisions but based on the same site sharing the same network. Division A is already using Lansweeper and we are about to purchase and use in our division. We are split into 2 different AD containers.
Could you advise?
If you install Lansweeper on a separate server and database you shouldn't have any problems.
