Options
‎03-04-2010 10:54 PM
I upgraded followed instructions for upgrading from the 2/18 beta 4 to the 3/2 beta 4 using the upgradebeta.sql script and now the info when viewing devices in the web page is just a bunch of SQL code. The following two screenshots are what I get when I click on Add New Device and when I try to view details of an existing device.
Labels:
7 REPLIES 7
Options
‎03-05-2010 03:03 PM
Ah, your question lead me to find the answer. I looked to see the owner of the DB which was lansweeperuser. I was logging in to the DB using windows authentication and using my domain admin account. So I tried again using SQL Server Authentication with lansweeperuser as the user, and it said both commands completed successfully (which is exactly the same message that I got when I ran the script as the domain admin user), but this time it worked. Thanks for the help.
To modify the DB, will I always have to login as the owner, and not just a local or domain admin?
Options
‎03-05-2010 03:06 PM
Normally you don't have to do this except for this fix to upgrade the beta.
Options
‎03-05-2010 02:39 PM
With which user were you logged on when you ran the script?
Did you ran it from the SQL server management console?
most likely the owner is not .dbo
Options
‎03-05-2010 02:34 PM
Yes, I applied the script to the correct db. I went ahead and ran it again with the "use lansweeperdb" code and it said:
Msg 2714, Level 16, State 3, Procedure web40DevActionsA, Line 2
There is already an object named 'web40DevActionsA' in the database.
Msg 2714, Level 16, State 3, Procedure web40DevActionsB, Line 2
There is already an object named 'web40DevActionsB' in the database.
After restarting all the services, I'm still getting the same issue when looking at the properties of devices and creating a new device.
Options
‎03-04-2010 11:09 PM
This was using the upgradebeta.sql you sent me yesterday. Everything seems to work, except for device properties and adding a device. I tried creating a sql script with the code you pasted above and running it against the SQL database instance and it didn't help. Do I need to run the upgradebeta.sql script again?
Options
‎03-05-2010 09:57 AM
It should work, are you sure you did it on the correct database?
If you doubt add "use lansweeperdb" at the top
use lansweeperdb
GO
CREATE PROCEDURE [dbo].[web40DevActionsA]
AS SELECT Description, Action, Icon, confirmation
FROM dbo.tsysdeviceactions
WHERE (enabled = 1) AND (Advanced = 1)
ORDER BY sortorder
GO
CREATE PROCEDURE [dbo].[web40DevActionsB]
WHERE (enabled = 1) AND (Advanced IS NULL OR
Advanced = 0)
ORDER BY sortorder
GO
Options
‎03-04-2010 10:58 PM
I've mailed you the missing sql script afterwards.
ORDER BY sortorder
GO
Advanced = 0)
ORDER BY sortorder
GO
