Bourne_Group
Upgraded to the premium version last week all was working fine,. After producing the reports that I needed I seem to have some SQL issues,
See below and if anyone can point me in the right direction to fix this please
WMI access denied 22 items 10.84 %
All workstations System.Data.SqlClient.SqlException: Invalid object name 'Web30repAllWorkstations'.
System.Exception: The DefaultView was requested but no tables yet exist.
at DreamweaverCtrls.DataSet.get_DefaultView()
Is it possible that you accidentally deleted view "Web30repAllWorkstations"
Is so, this is the sql code to recreate it:
SELECT     dbo.tblComputers.Computername, dbo.tblComputers.Domain, dbo.tblComputersystem.Domainrole, dbo.tblComputersystem.Lastchanged
FROM dbo.tblComputersystem INNER JOIN
dbo.tblComputers ON dbo.tblComputersystem.Computername = dbo.tblComputers.Computername
WHERE (dbo.tblComputersystem.Domainrole < '2')
