rrobledo
The report works just fine. I gathered this report from https://www.lansweeper.com/forum/yaf_postst7630_Reporting-on-Memory.aspx#post32011 and am trying to adjust to a chart. When adding 'count' the numbers are not correct. Any help is appreciated.
Select Distinct Top 1000000 tblAssets.Memory,
Count(tblAssets.AssetID) As Total
From tblAssets
Inner Join tblPhysicalMemoryArray On
tblAssets.AssetID = tblPhysicalMemoryArray.AssetID
Inner Join (Select tblAssets.AssetID,
Sum(Ceiling(tblPhysicalMemory.Capacity / 1024 / 1024)) As Memory,
Count(tblPhysicalMemory.Win32_PhysicalMemoryid) As Used
From tblAssets
Left Outer Join (TsysMemorytypes
Right Outer Join tblPhysicalMemory On TsysMemorytypes.Memorytype =
tblPhysicalMemory.MemoryType) On tblAssets.AssetID =
tblPhysicalMemory.AssetID
Group By tblAssets.AssetID,
Having tblPhysicalMemory.MemoryType <> 11) CorrectMemory On
CorrectMemory.AssetID = tblAssets.AssetID
Inner Join tblPhysicalMemory On tblAssets.AssetID = tblPhysicalMemory.AssetID
Inner Join TsysMemorytypes On TsysMemorytypes.Memorytype =
Where tblPhysicalMemoryArray.[Use] = 3 And tblAssetCustom.State = 1
Group By tblAssets.Memory
0 REPLIES 0
