Guru_Prasad
Dear All,
I am a Premium version user. I need to find whether systems is enabled with USB storage or not. Can I able to find it using Lansweeper?
Awaiting for the response.
Regards,
Guru.R
It's in the premium forum:
You need to upgrade your status to premium user first : http://www.lansweeper.com/forum/premiumforum.aspx
Guru_Prasad
Not able to browse the link provided. It says i dont have access to the post.
See this thread : http://www.lansweeper.com/forum/yaf_postst2865_USB-Devices.aspx
