Options
‎06-18-2010 08:37 PM
How to reset username/password that lansweeper uses to connect to SQL?
I get the following eerors:
System.Data.SqlClient.SqlException: Login failed for user 'lansweeperuser'.
thanks
thanks
Labels:
Options
‎06-21-2010 06:54 PM
This can only be caused by:
1) username/password wrong on the database.
2) username/password wrong in the config files.
3) sql user locked out.
4) database not configured for mixed authentication.
Options
‎06-21-2010 03:36 PM
Thanks, I did all that, but its still logs the erros of invalid password.
everytime I restart teh service I get the following:
6/21/2010 9:31:16 AM: Cannot connect to database, check your config file, service will be stopped
Cannot open database "lansweeperdb" requested by the login. The login failed.
Also the website shows this: see attachment
Options
‎06-19-2010 09:47 AM
To reset the password on the database you need sql server management studio (which is a free download if you use sql express)
You also need to change the password in web.config and lansweeperservice.exe.config
