jmarmo
Are there any (working) scripts that display a computers version of IE, and also allow you to see a list how many of each versions are found and all computers with that version?
jmarmo
Thanks. That worked
The file was not detected on any of your machines because you submitted an incomplete file path. Please have a look at the example in the forum thread linked in our previous post and make the necessary changes under Configuration/Scanning Setup/Custom Scanning.
jmarmo
After following the directions. This is what the report looks like. Notice no version information.
Please refer to the information in this forum thread: http://lansweeper.com/forum/yaf_postst5554_Internet-Explorer-9-report.aspx
Some IE versions are not listed under Add/Remove Programs and therefore not scanned as part of standard software scanning. You can detect these installations by performing a custom file scan instead.
