AndyB
I've searched the forums and haven't found and answer so I'll give posting a go. I've set up a report which I hoped to show the comments from each server, even when blank. The report runs and shows only the servers that have the comment field populated.
I have a feeling that tblAssetCustom.State is where I need to make the change, anything other than "1" causes the report to fail or returns no results.
the report code is below:
tblAssets.IPAddress,
tblAssetComments.Comment,
tblAssetComments.AddedBy,
From tblAssets
Inner Join tblAssetComments On tblAssets.AssetID = tblAssetComments.AssetID
Thanks for your help,
-Andy
You report looks ok.
With "blank comments" do you mean "no comments" or "comments without any text"?
