kickboxer
I've installed using SQL express and used the defaults for a named instance
I've got a few problems with the new version of Lansweeper, the first one with IE
Line: 134
Char :3
Code:0
Error: Automation server cant create object
ALso I cant run the Lansweeper pro console
Get the error
DBNETLIB [ConnectionOpen(Connet().] SQL Server does not exist or access denied
using the SQL account - lssqluser
TIA
dave
First problem : search the forum on how to configure internet explorer to get the actions to work (trusted zone, activex security)
second problem : either your servername is wrong or your login/password
Named instance : servername\namedinstancename
Default instance : servername
