Treppenmeister
I have problems to install Lansweeper.
1st try:
Installation on a XP SP3 workstation. As SQL Server for the database was chosen the one from a SBS 2003.
The installation on 3 clients (all users were domain admins) worked fine. My attempts on other computers to install the service (as local admin only) didnt work. The installation stopped on the Lansweeper Database Configuration page. Error-message 'In order to successfully connect to SQL Server, following items must be accomplished ...
- Protocols "named Pipes" and "TCP/IP" must be enabled
- "SQL Server Browser" must be running
Why I could install from 3 computer and now it suddenly failed?
So i deinstalled Lansweeper again and tried my luck with the SQLExpress 2005 version. But the installation worked only on the server itself. On a client the server on which SQLExpress 2005 was installed doesnt appear in the dropdown list. When i add it manually and choose Windows Authentication, then the same error as above is appearing.
What am i doing wrong?
Edit:
After the restart of the computer where SQLExpress 2005 was installed on, i find that computer in the dropdown list. But it doesnt change the fact that i cannot connect the SQLserver from the client
18 REPLIES 18
Treppenmeister
Thanks - this helped. Now all looks fine.
See point 6 on this page : http://www.lansweeper.com/kb/accessdenied.aspx
Treppenmeister
There is written
Congratulations, your lansweeper service is running
Freeware version - Active scanning disabled
Total computers processed: 38
In queue 0 In process 1 Threads running 1
c-dt
C-DT
So the WMI is corrupt on my computer? How to repair it?
Could you take a look at the server scanning screen http://127.0.0.1:9524 on the server.
Some computers with corrupt wmi installation get stuck in the queue.
If this is the case you can repair the wmi on this computer.
Treppenmeister
Here are 2 screenshots
*** edited ***
This computer is showing red but you don't see any error tab?
Could you post any screenshots of this please.
Treppenmeister
There is no error tab.
I had one before WMI was working. After changing the firewall settings it disappeared.
(we are talking about the site
http://tmsrv02/lansweeper/default.aspx?item=compdetail&comp=computername ? )
When you click the computer on the website/tab errors what is the exact error?
Treppenmeister
Now - after the restart of my computer it appears again in the database - but only red.
In Service\Errorlog.txt there is no new entry.
When i start the connection tester from the server and test the client then all is ok:
Remote WMI test
Found: Microsoft Windows XP Professional Service Pack 3
Found: Microsoft Windows XP Service Pack 3
What could cause the problem?
