jasonbrink
I installed lansweeper on our WSUS server running SQL 2005/IIS7/Windows2008R2.
The lansweeper install went okay, but now the WSUS service isn't running, and either is lansweeper. Below is the error I get. Please help!
7 REPLIES 7
Could you try running this script:
c:\inetpub\AdminScripts\adsutil.vbs set w3svc/AppPools/Enable32bitAppOnWin64 0
Search for the correct path of adsutil.vbs first
jasonbrink
So it might have something to do with the web.config or applicationhost.config file? Not sure what to look for! Thanks for any help.
jasonbrink
What do you need a screen shot of?
In your last screenshot there is a text "most likely causes"
Could you verify these?
Could you verify the most likely causes in the screenshot
jasonbrink
Could you please post the install.log file.
And a full screenshot if possible.
