Joseph_Earley
When I run a report on software I notice some computers have more than one version of Java JRE. When I log on to the computer it only shows one version installed. Why are the reports in Lansweeper showing extra versions?
patrick_hanly
Thank you for pointing me in he right direction. It appears the report I was looking at had the same issue.
The problem was that the customer created an incorrect report; there was nothing actually wrong with the data that was scanned. The customer based his report on tblSoftwarehist, which lists software history (installations/uninstallations) and does not reflect what is currently installed on a machine.
If you are having issues with software scanning, please contact support@lansweeper.com and provide us with screenshots of the problem.
patrick_hanly
Is there any update on this topic? I am seeing the same issue.
Please contact us at support@lansweeper.com and provide us with screenshots of the following:
- Web console page for one of the affected computers. Show us the Actions tab as well as the Software tab.
- The computer's software list under Programs & Features.
