Mitnick
Hello, we have the problem that we can no longer simply log on SQL Server Lansweeper.
If Connection Failed password but we have never been there or something award.
How can we fix it?
The default password is: mysecretpassword0*
If the password for "lansweeperuser" was changed, it should've been changed in the following files as well:
Program Files/Lansweeper/Service/Lansweeperservice.exe.config
Program Files/Lansweeper/Website/web.config.
Mitnick
No lansweeperuser is the self answer ^^
we dont have a password for this user
Can you try using sql user "lansweeperuser"
