nilesf
Okay Lansweeper from what ican see in functioning correctly. It is just simply not collecting data. I also notice that there is a way to schedule scans, but it only allows me to enter in one computer name at a time. Is there a way to import my Active Directory list of computers?
Thanks,
Niles
15 REPLIES 15
nilesf
Disregard my last post. I forgot to confirm the password in the third field. Still no luck with though.
nilesf
I also discovered this whe I tried to confirm the passowrd.
TITLE: Microsoft SQL Server Management Studio Express
Change password failed for Login 'nfosteradmin'. (Microsoft.SqlServer.Express.Smo)
For help, click: http://go.microsoft.com/fwlink?ProdName=Microsoft+SQL+Server&ProdVer=9.00.3042.00&EvtSrc=Microsoft.SqlServer.Management.Smo.ExceptionTemplates.FailedOperationExceptionText&EvtID=Change+password+Login&LinkId=20476
ADDITIONAL INFORMATION:
An exception occurred while executing a Transact-SQL statement or batch. (Microsoft.SqlServer.Express.ConnectionInfo)
Cannot alter the login 'nfosteradmin', because it does not exist or you do not have permission. (Microsoft SQL Server, Error: 15151)
For help, click: http://go.microsoft.com/fwlink?ProdName=Microsoft+SQL+Server&ProdVer=09.00.3042&EvtSrc=MSSQLServer&EvtID=15151&LinkId=20476
BUTTONS:
OK
nilesf
No. It returns "Failed" The server is runnig a fresh install of Windows 2003 R2 x86. No Firewalls and is on the same IP range as the workstation where LSclient is being run. I did find that there is an error with the login account that I am using. Please advise.
4/4/2008 4:48:18 PM
System.Data.SqlClient.SqlException: Cannot open database "Lansweeper" requested by the login. The login failed.
Login failed for user 'nfosteradmin'.
at System.Data.SqlClient.SqlInternalConnectionTds.CompleteLogin(Boolean enlistOK)
at System.Data.SqlClient.SqlInternalConnectionTds.AttemptOneLogin(ServerInfo serverInfo, String newPassword, Boolean ignoreSniOpenTimeout, Int64 timerExpire, SqlConnection owningObject)
at System.Data.SqlClient.SqlInternalConnectionTds.LoginNoFailover(String host, String newPassword, Boolean redirectedUserInstance, SqlConnection owningObject, SqlConnectionString connectionOptions, Int64 timerStart)
at System.Data.SqlClient.SqlInternalConnectionTds.OpenLoginEnlist(SqlConnection owningObject, SqlConnectionString connectionOptions, String newPassword, Boolean redirectedUserInstance)
at System.Data.SqlClient.SqlInternalConnectionTds..ctor(DbConnectionPoolIdentity identity, SqlConnectionString connectionOptions, Object providerInfo, String newPassword, SqlConnection owningObject, Boolean redirectedUserInstance)
at System.Data.SqlClient.SqlConnectionFactory.CreateConnection(DbConnectionOptions options, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningConnection)
at System.Data.ProviderBase.DbConnectionFactory.CreatePooledConnection(DbConnection owningConnection, DbConnectionPool pool, DbConnectionOptions options)
at System.Data.ProviderBase.DbConnectionPool.CreateObject(DbConnection owningObject)
at System.Data.ProviderBase.DbConnectionPool.UserCreateRequest(DbConnection owningObject)
at Lansweeper30.starter.startsweeper()
When you run the lsclient do you get a "success" message?
Is your errorlog.txt in the service directory empty?
nilesf
No errors that I can see. The problem is that I do not see any data populating in Lansweeper. I ran the lsclient but still nothing.
Thanks,
Niles
What's the exact problem?
Do you see any errors in the log?
Have you issued lsclient.exe on the clients?
I'm currently programming this as a premium user tool.
