I read a thread that lansweeper would be able to install in a multidomain enviornment.
I currently manage two different domains and i have a management network that is just a workgroup. I have lansweeper installed web/db/service all on a single non domain machine. i read that you can install the service in each domain and point back to a central sql server. however whenever i try to install the service in either domain, it cant connect to the sql server.
i've enabled remote connections / sql broswer.
l also see these errors in eventvwr on my lansweeper machine.
- SSPI handshake failed with error code 0x8009030c while establishing a connection with integrated security; the connection has been closed.
and
- Login failed for user ''. The user is not associated with a trusted SQL Server connection
how can i specify a user during install? or is there another way?
