gdavid
I read a thread that lansweeper would be able to install in a multidomain enviornment.
I currently manage two different domains and i have a management network that is just a workgroup. I have lansweeper installed web/db/service all on a single non domain machine. i read that you can install the service in each domain and point back to a central sql server. however whenever i try to install the service in either domain, it cant connect to the sql server.
i've enabled remote connections / sql broswer.
l also see these errors in eventvwr on my lansweeper machine.
- SSPI handshake failed with error code 0x8009030c while establishing a connection with integrated security; the connection has been closed.
and
- Login failed for user ''. The user is not associated with a trusted SQL Server connection
how can i specify a user during install? or is there another way?
13 REPLIES 13
Geno
Happy it worked out. Info provided by Lansweeper sure comes handy with workgroups.
And the gpo logon script, is correct aswell. I have it set exactly the same way. I think it was because with initial testing it showed me errors, and when I did 'echo %logonserver%', I switched to \\fqdn\netlogon aswell.
gdavid
Lansweeper,
Thanks for support! this worked perfectly. I really like this application, its very quick and easy to deploy to clients.
Also a note for your GPO logon script. if you have a mix of domain and non domain machines or you login in locally. you may want to change the \\%LOGONSEVER% to \\domain.name ex: \\company.local\netlogon\
\\%LOGONSEVER% gives you the local machine name if you login locally.
Geno, i found your post in google about multi domains under a single forest. thats what prompted me to try this application to begin with. very few apps are friendly to mixed credentials.
Thanks for all the help. this is all working perfectly for me now.
Geno
I posted it a while back, but deleted. I figured it was a known problem as I didn't get a reply on my solution nor my suggestion to provide credentials during installation.
The way I did it was Way simple because I have all domains in a forest.
I simply logged in with the domain admin user where my sql server is and installed it without trouble.
This will not work if you have totally different domains.
Download http://www.lansweeper.com/debug/srvinstw.zip
Copy your service folder from the working server (with config file) to the domains.
Install the service with srvinstw.exe and choose the correct domain credentials.
gdavid
i'm dont completely understand the workaround.
copy/paste the database from where?
this is my goal.
WKRGRPSERVER - www/db/service (already working)
DOMAIN1SERVER - (needs service installed)
DOMAIN2SERVER - (needs service installed)
i'm kind of new to this application as a whole. the only reason i want to do it this way is because i assume after i get this part working. DOMAIN1 machines can use lsclient to send back to DOMAIN1SERVER and the same for DOMAIN2.
which will then send all data back to a central database. and be pretty.
unless of course i can specify the login credentials for each subnet in the application somewhere 🙂
I see, this is an installer issue.
The installer tries to connect to the SQL server with NT authentication (I need to fix this)
As a workaround you can copy/paste your database to the sqlserver.
Restore as database Lansweeper32
Create a sql user lssqluser32, password the same as in the config file.
Make the user owner of the Lansweeper32 database.
gdavid
my standalone installation of lansweeper on the workgroup machine works fine.
that error is created on the workgroup server when i run the installer on a domain machine to install the lansweeper service.
that error is SOURCE=MSSQL$SQLEXPRESS ID=18452
Do you get this error in the installer or when starting the service?
gdavid
i have my lansweeper service / www / db installed on WRKGRPSERVER
curious why you asked for the config file?
how does it know about the config file? it seems its using the account i log into the domain machines with to create the connection thats failing.
when i'm installing the service on the other domain machines i'm using the installer file that i downloaded from your website. it asks me for the database location in the form of SERVER\INSTANCE
is there another way to install the other parts? should i be installing it from a exe from my current install?
thanks again.
GD
