Naushad
Hi...
I have setup Lansweeper on a server and have deployed the lsclient via the startup.cmd script in a user's profile. But now I want to deploy it to a group of users via logon.bat files. We have 8 different logon batch files for different groups in the company. So I added the line "%logonserver%\netlogon\lsclient.exe lansweeper" to the logon.bat files. But it does not seem to work. I also tried adding "%logonserver%\netlogon\startup.cmd" to see if it that would work but it doesn't either.
I havent tried deploying via GPO but that would be my last option. I would like to logon.bat files. Any help? Any ideas?
Thanks,
Naushad
Naushad
Yes I did copy the lsclient.exe to the netlogon folder. But due to time constraints, I had to go with the GPO method, which has worked on a test OU. I have now applied to all users. I am just waiting for computes to show up on Lansweeper.
Thanks for your help.
Naushad
Did you copy lsclient.exe to the netlogon folder?
Can you manually run "%logonserver%\netlogon\lsclient.exe servername"?
