Options
‎02-22-2011 05:38 PM
When we use the remote control tool (lsremote) to remote a screen size that is greater than ours, we have to scroll or use the option on the right click menu to Auto-Scale the screen (Ctrl+Alt+F10). We can't seem to find a way to set the these options globally. Is there a config file that we can place in the Actions folder that will do this for us? Or, is there a command line switch we can append to the custom action?
Lansweeper Version: 4.1.0.103
LSRemote Version: 3.0.0.21
Thanks in advance
Thanks in advance
Labels:
Options
‎07-06-2011 08:32 PM
cool I did not know we could right click and get some options 🙂
In any case , the auto scale window option is great, but unfortunately it does not save that option so you must set it each time. I've just tested that.
o well
o well
Options
‎02-23-2011 09:55 AM
You cannot use any additional command line parameters.
The easiest way will be to setup everything correctly, then export the registry key into a .reg file.
Options
‎02-22-2011 10:04 PM
I tried adding these values one at a time, still can't get it to auto-scale:
"AutoScaling"=dword:00000001
"Scaling"=dword:00000001
"Scale_num"=dword:00000086
"Scale_den"=dword:00000100
I noticed that you have the default of:
"{actionpath}lsremote.exe {computer} /NP" in the custom action.
Is there a help file for these settings or can you send me some parameters. I looked at http://www.uvnc.com/install/cmdline.html but these do not help either.
Options
‎02-22-2011 08:17 PM
The settings are stored in HKEY_CURRENT_USER
You can create a .reg file for this.
