ifm
"LS Remote Control Temp" is left on the computer after i disconnect.
Can you please fix this in the next update?
Untill then Ill put a clean script in my startup script.
Will do in the next version.
ifm
Ok, cant you "hide" it in the windows or %temp% folder instead? 🙂
It stays there on purpose.
Next time you run lsremote it checks if it needs to copy the files first. This saves time/bandwith on slower connections.
