rui_real
so i'm trying to do my lansweeper scans with Lspush.exe agent. I created a Schedule and it keeps updating every 30 minutes my Lansweeper. The only problem is that everytime logs the event error 1001, like if the application failed unexpected. Any ideas?
SO Windows 7 - 64bit Lansweeper 5.3.0.22
Thank you for your help.
As I don't see any recent tickets from you in our system, I'll consider this issue resolved for now. I'm not aware of LsPush generating any Event Viewer errors or other customers reporting similar issues. Without details on the error, it's difficult to comment on this further.
Could you post the details of the Event Viewer entry, as well as the script or command you're using to run LsPush. It's difficult to comment on this with an event ID alone.
