Sujitha_L_M
Dear Concern,
We bought a new Hand held device (Bar Code Scanner) into our Network. It is being issued with our IP. But when we checked with the same IP in Lansweeper there is no such entry.
We tried to run Lspush in that device. Soon we got an error stating "Lpush is not a Valid Pocket PC Application". If any device connects to our network, Lansweeper can able to trace out the systems. But its not happened in this case.
Is there any possibility of having the device entries in Lansweeper.
Thanks & Regards,
Sujitha L M
If your device supports SNMP, you can scan it through IP Range Scanning. LsPush only works for Windows 2000 and higher.
Sujitha_L_M
Okay. the OS for that hand held Device is Windows CE.
We thought as if the Lspush is compatible for all Windows OS.
Please note that LsPush only works for Windows computers running Windows 2000 or higher. Other devices can only be scanned through IP Range Scanning.
Sujitha_L_M
We copied the Lspush. Exe file to the device. After executing that we got this error.
Can you send the output of the devicetester from the server to this device please.
