pmcnamara
We are running SBS 2003 and have windows xp and vista workstations. However, we are unable to get lstrigger working on any workstation. The connection test passes fine, on any workstation. is there a relationship between the RRAS service and the client and/or lstrigger? We need RRAS in order for Active Sync and Blackberry server to function properly, but we are stuck on what to do here. We have read every article in the forums on lstrigger, and can't see a solution that works for us.
10 REPLIES 10
Do you also have an error in the errorlog.txt about this?
btrinidad
Reading a different post about lsclient I noticed that my Lansweeper service will not run, its starts and then stop with an error
Event Type: Error
Event Source: .NET Runtime 2.0 Error Reporting
Event Category: None
Event ID: 5000
Date: 6/10/2008
Time: 2:04:55 PM
User: N/A
Computer: SAV01
Description:
EventType clr20r3, P1 lansweeper31.exe, P2 3.1.3028.22480, P3 4805f4fe, P4 microsoft.visualbasic, P5 8.0.0.0, P6 4333d6d8, P7 377, P8 172, P9 system.invalidcastexception, P10 NIL.
there are some .net updates that i am missing
I am running that now and I will try again
btrinidad
Is there an instruction manual for this software? How do I use lsclient?
When you browse the lansweeper site, do you see the computer?
Best way to add it is using lsclient.exe
btrinidad
i modified my command to: lstrigger sav01 btrinidadxp acsisinc
same result
when you say computers already in the database what does this mean exactly?
I have added the computer to the Management Console under scan options and scheduled scanning
Is this how you mean to add a computer to the database?
The domain expects a netbios domain name, could you try this please.
lstrigger only triggers computers already in the database (and they are all stored using their netbios domain name)
btrinidad
My server name is sav01
The name of the client pc is btrinidadxp
my domain name is acsisinc.com
the exact command i am typing is: lstrigger sav01 btrinidadxp acsisinc.com
Could you give the following information to solve this problem
Name of your server (where the service is installed)
Name of the client to trigger
The exact commant that you are typing
btrinidad
I am having the same issue. I am running lstrigger from a stand alone 2003 server, the connection test passes but when i type in the lstrigger command it says connecting... then fails
