We run Lansweeper on a Windows 2008 R2 x64 server and I just noticed that even though a 64 bit version of MS SQL 2008 is installed (atleast I think it is 64 bit because there are files in both %PROGRAMFILES% and %PROGRAMFILES(x86)%) MS SQL run as a 32 bit process.
The database is 3,99 GB (4 294 180 864 bytes) and Lansweeper webservices is extremely slow and painful to use. I suspect that we hit a size limit in the 32bit version.
When Lansweeper 5 is released, is it better to do a fresh start, reinstall the server with Windows Server 2008R2 x64 and run the Lansweeper install wizard, or should I try to migrate the SQL to 64 bit and then run a regular upgrade?
