JamesinIT
I notice that Lansweeper picks up several of my company desktops and servers that are running SQL MSDE or SQL Express 2005 as full SQL servers. Is there any way to create a custom field to indicate that this is a full version or express?
Which is the report you are referring to?
Unfortunately you cannot see in the add/remove programs is a sqlserver is enterprise/standard/express.
All Microsoft.
I see that for SQL 2005 it doesn't show versioning information (it does for the others).
I am going to add a custom field and add it to the report so I can keep track (I already know which are and aren't, so it'll just be a bit of manual effort.)
