sique
I've tried to upgrade two installations, and do a fresh install, and all three gives the same error (this exact error is from a fresh install):
Error:
C:\Program Files\Lansweeper\GUIConsole\lsmanage.exe
An error occurred while trying to copy a file:
The source file is corrupted.
Click Retry to try again, Ignore to skip this file (not recommended) or Abort to cancel installation.
For the two upgrades I chose to ignore the error, and the installation finished without further problems, and LanSweeper works, but of cource, lsmanage.exe is missing.
Any ideas? May I download lsmanage.exe from somewhere?
sique
I downloaded a new setup.exe and that one worked fine, thanks for the tip!
Most likely you need to redownload the setup.exe file.
You can download lsmanage.exe from http://www.lansweeper.com/debug/lsmanage.exe
