Mamba
We're now running the latest Lansweeper version 4.2.0.60.
In the past I occasionally used the MS SQL Management Studio Express version but that was for SQL Server 2005.
I've tried downloading and installing a couple 2008 MS SQL Express versions but none will give me the option to install the Studio. The instance reported is MSSQLServer 10.50.1617.0.
I need to run some queries; can someone shed light on how to get the proper Studio installed?
TIA,
M
Mamba
Well, that's workable if not as convenient as the Studio. From reading past posts here, Support used to recommend installing Studio. Tx...
Could you clarify why you need SQL Server Management Studio for this? You can run queries on the Lansweeper database using the Lansweeper report builder. The report builder is located in the configuration console under Reports & Alerts\Report Builder.
Scripts can be executed in the configuration console under Lansweeper\Database Scripts.
