dteague
OK, been having issues with the report writer crashing on me, or hanging sometimes. When it works it's great.
I'm hoping someone can help me, as it has been years since I have done much in SQL. What I need is a list of computers that their name does not match their IP address's 4th node.
i.e. ABCCOMP043 should have an IP address of 10.0.0.43 if it had an address of 10.0.0.44 I would want it to show so I can rename the computer. Can someone help me out?
Thanks!
dteague
The Hangs, seems to happen all the time in report writer when I am trying to write a query. It usually happens when I am in the SQL tab trying to write an SQL statement, and it will "hang" and take 1 processor up to 100% and after a few minutes it will do one of 2 things, it either comes back, or it just stays there, and I kill the task. It's running on a VM that we have devoted 4 processors and 4G of memory.
I've also noticed that sometimes the query will not run unless I bounce thru the tabs a few times, as it doesn't produce the results after I change a query.
This is a known problem, an update will be released for it soon.
Do you know when exactly this happens so we can try to reproduce this?
