Options
‎08-25-2010 04:53 PM
I am having trouble figuring out why most of my switches and other network devices show up without any descriptions. The switches are Cisco Catalyst 6500 and that is listed in the device lookup table. All I get is the IP address in the record.
Labels:
Options
‎08-31-2010 05:18 PM
Is SNMP enabled on those switches? Without SNMP, LS has no way of getting any real information from them besides the header responses of the HTTP server (which I'm not sure if it even uses).
If SNMP is enabled, but you are using a community string other then public, you'll need to set the community string you use in the LS Configuration Manager. Scanning Setup -> Scanning Servers -> IP Range Scanning -> Credentials -> SNMP Community String
If SNMP is not enabled, it is rather easy to enable. For IOS, just telnet into the switch and run 'snmp-server community YOUR_COMMUNITY_NAME RO' to enable YOUR_COMMUNITY_NAME as a read only community. I don't use CatOS, but it shouldn't be that much more involved. (Don't forget to write your config)
