cheiner
I cannot log into the GUIConsole management Console;
Username "lssqluser31" (dont know the password).
I have uninstalled and re installed to use Windows authentication or the lssqluser31; Lansweeper31.exe.config says; and tried it wiht the administrator account.
I can access SQL Server management using the administrator access under Windows Authentication and can verify the lansweeper31 Database.
Catalog=Lansweeper31;User ID=lssqluser31;Password=mysecretpassword0*"/><add key="ConcurrentThreads" value="20"/><add key="ListenPort" value="9524"/></appSettings></configuration>
DOTNET 2.0 installed, SQLexpress installed.
lansweeper31 SQl database was created.
http://servername/lansweeper31/ virtual web comes up ( no data in it)
Connection testor successfull, OK all the way round
Error Log below;
5/27/2008 10:03:39 AM : Cannot connect to database, check your config file, will try again in 1 minute
Login failed for user 'lssqluser31'. The user is not associated with a trusted SQL Server connection.
5/27/2008 10:04:39 AM : Cannot connect to database, check your config file, will try again in 1 minute
5/27/2008 10:05:39 AM : Cannot connect to database, check your config file, service will be stopped
See this microsoft KB article:
http://support.microsoft.com/kb/555332
