danielm
Does anyone have any tweeks to the lansweeper application pool?
I've noticed the default WorkerProcess # is set to 1.
Will the system work with more than 1 set?
I've tried a setting of 2 and it does seem to make a difference on some of the main page/tab loads. Is that just me?
any suggestions here to for optimization.
I'm running under WIN7pro IIS
danielm
no issues really. the speed is usually fast , now and then it would pause for maybe a second or 2 depending but I also have other things running on that machine using sql. I was just playing with some settings and was wondering if this made any improvement.
Development hasn't played around with this much to be honest. Do you have any specific web console issues? How many assets are in your database?
