Anonymous
Not applicable
I'm doing an installation over an SQL test machine, can you please point me the order of sunning the SQL scripts to upgrade the database from version 19 to the 5.0 beta one?
I think I'll have to run these, but what's the order?
populatedata.sql
tables.sql
views.sql
procedures.sql
Right? thank you very much, I'll have to test everything before going into productive.
Anonymous
Not applicable
Thanks for the input, I will try with the service first then.
The sql upgrade scripts are embedded in the service and they run as soon as the service starts. (there are different scripts for sql compact and sql server)
If you need the scripts for testing, please contact us by e-mail.
