loerdy
The page cannot be found
The page you are looking for might have been removed, had its name changed, or is temporarily unavailable.
Best regards,
loerdy
loerdy
it works fine!
Many thanks!
To configure authenticated access, do the following:
- Configure your web server for authentication. If your web console is hosted in IIS Express, run the ExpressAuthentication.exe in Program Files (x86)\Lansweeper\IISexpress on the server hosting your web console, select Integrated Authentication and hit Change.
- Add your AD user groups to the Configuration\Website Access section of the Lansweeper web console. Note that you must submit AD user groups and that you must use the format NetBIOS domain name\group name. The following would be a valid entry for instance: lansweeper\administrators. You can assign a group to one or more roles.
loerdy
And I understand it's a link to the ToDo
The "TODO" next to the article name means that this article does not yet exist. We will create it when we have our new knowledge base up and running.
