Current tools are in development at the moment, please let me know if you have ideas for new tools.
One click active directory inventory
Use this program to scan your complete active directory at once (servers or clients or both)
For example : you can use this program as a scheduled job to scan all your servers in the weekends, ...
Visual query/report builder
Create reports/views from this interface and add them to the existing reports.
Outlook profile generator
Generate outlook profiles on your clients from the login script, no need to manualy set the outlook profile on your user's computers.
MoultonCollege
Outlook Profile Generator would be really useful as every time we set up a new member of staff we have to log on and sort their outlook profile for them before they start
I'd like to see the report builder made easier to use, I've got no idea how to write in SQL
RAFF37817
We have a hundreds of applications in our evironment.
I would like to see a listing of Disallowed software (a blacklist) added.
yrbrands
The ability to scan selected OU's rather than the entire AD forest.
Alex_Viner
Extend Software License Compliance section to provide the ability to logically group several versions of installed products based on the license agreement rules.
Thanks,
alex
Pollak
Remotely uninstall applications would very usefull. I find tons of unwanted software on our network.
Thanks,
Niles
